routing-policy
Creates a routing policy and enters
its configuration mode
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
routing-policy <ROUTING-POLICY-NAME>
Parameters
| <ROUTING-POLICY-NAME> |
Specify the role policy name. If the policy does not exist, it is
created. |
nx9500-6C8809(config)#routing-policy test
nx9500-6C8809(config-routing-policy-test)#?
Routing Policy Mode commands:
apply-to-local-packets Use Policy Based Routing for packets generated by
the device
logging Enable logging for this Route Map
no Negate a command or set its defaults
route-map Create a Route Map
use Set setting to use
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
| no
Removes an existing routing policy |
For more information on Routing Policy
commands, see
Routing Policy.
